Woke up this morning and the pool was running because the FRZ indicator was on. It was 55 degrees outside. I looked at the manual for the pool controls and saw I could adjust the pool and air temperatures so i did. However, the control panel will not let me set the water temperature below 88 degrees and the water is actually 50 degrees. My pool control panel is a Compool CP3400.
When i cycle through the calibration temps I only get pool and air temp. I don't have any other sensors installed. Out of curiosity I also wonder why I don't have a sensor for the hot tub. I assume it used the same one as the pool.
Thanks in advance for any help.
