If there's any electrician or anyone with such knowledge here, I'd really like your advice.
Our primary home electrical breaker box is on the opposite side of my pool equipment. So facing the front door entry, breaker box on left side and pool equipment on right side. My garage is also on the right side (more later on why this is mentioned).
When my pool electrical was ran, they dug everything under ground and set up a subpanel or breaker box for the pool equipment. I'm not sure how many amps or volts and all that is, but it's currently handling my pool pumps (2 VSPs), Aqualink, and heater and whatever else as part of my equipment.
So now in the middle of July, our garage gets really hot, and we have a garage gym built in part of our tandem 3 car garage. We're looking to add a 24k BTU mini split AC but to run the electrical line from the opposite side to this side, it can get difficult and expensive.
So the electrician came out today (who actually did my pool electrical) and long story kept short, he says my pool electrical subpanel will be able to handle the mini split. He said he can run a line off the pool panel, and I should be okay. I expressed some concerns and he said if it doesn't work, he can always run a bigger wire to the pool electrical box and then it should handle it. Of course the costs would be additional if that happens.
The mini split guy gave me these as the specs for the electrical setup he'll need before installing the mini split:
12/2
Disconnect box
20 amp circuit
Any advice?
Neil
12/2
Disconnect box
20 amp circuit
Any advice?
Neil
