Pool Store Water Analysis vs. Taylor Pro
Megarms
114
Eldersburg, MD
I know this has probably been rehashed, but I can not find anything recent.
I have been trying to decide how much salt to add to my pool, as my Taylor drop test says I am at 2800 ppm and the Jandy chlorinator says it is at 3500 ppm. Not wanting to add too much salt, I decided to take my water to the local pool store and compare tests. Well, to my surprise, many of the pool store tests (including salt which they say is 2400) were no where near what my Taylor drop tests have been.
So, here I sit again, wondering which test is the most accurate. Any thoughts?
You know the answer. 😉
I'll give you the only answer I've seen to be true over and over and over. Taylor 1766 is the one to go by. Remember it's accuracy (+/- 200 ppm I believe). None of the common tests are super accurate but The Taylor drop test is one to hang your hat on and plenty good for operation. Salt cell readings are notoriously inaccurate especially when they get deposits which of course you can't see. Pool store tests?? Well you know where we stand on that one!
We would send you to the pool store for free if they did better than Taylor. I have gotten exactly $0 from Taylor or TFT. Nate at TFP keeps adding 0s to my paycheck here but when the first # is also a 0, its mostly symbolic ($0.0000000000000 / etc). Still. Its the thought that counts.
But yeah. The poolstore test isnt designed for accuracy, its designed to sell chemicals, so we had you spend good money on a reliable kit to be able to test yourself. I had a newb who is now a friend that had 8 purchases suggested on his 'free' results. With clear water and reasonably in range. Accuracy is not in their MO and asking them only serves to make you question your own results.
Reactions: Donldson
If it helps, the pool store is always 800 ppm less than my Taylor test. I’m on my second set of chemicals too with consistent results.
My ph drop test is much easier to match colors with 4 drops vs the recommended 5 drops. This is a tip I got from others here on tfp.
Your Jandy SWG is reading high when your salt is in fact reading low. That’s usually an electrical problem with the SWG that could signify dying cell. How old is the cell?
Reactions: PoolStored
Not OP, but i have the same cell. I thought the cell reading lower then Taylor test was an indication it was dieing. Is reading high also a problem? My cell is 2 years old and has always been 500 or so above my Taylor test.
