+ 1. That would be fun to show friends. Hey XYZ remember how you guys went with waterfalls instead of a diving board ? *giggles and turns on the water*That’s a cool diving board!
So I researched this a lot. The best thing I found to do is to use a cooling infill because any turf will get very hot on bare feet. I picked a very plush and soft turf that is 1.75” high. I used a little over .5lb of cooling infill per sq/ft. mixed with the same amount of filter sand. The material settles in and really isn’t that noticeable on your feet. The material holds water for 3-4 days. If you don’t get rain within that time, you can hose it down.That looks fantastic! Question about the turf. On football fields, you see the black rubber pellets which keep the blade from matting down. Do you use those also? Do they pick up any on wet feet? I’ve always wondered about that. Again, awesome looking project!!
looks amazing.So I researched this a lot. The best thing I found to do is to use a cooling infill because any turf will get very hot on bare feet. I picked a very plush and soft turf that is 1.75” high. I used a little over .5lb of cooling infill per sq/ft. mixed with the same amount of filter sand. The material settles in and really isn’t that noticeable on your feet. The material holds water for 3-4 days. If you don’t get rain within that time, you can hose it down.
