- Jun 24, 2021
- 15,860
- Vinyl
- CircuPool RJ-60 Plus
Water hardness is a measure of the dissolved calcium and magnesium in the water. Adding calcium will raise hardness.
The reason I ask about your fill water. If your fill water has high calcium, then it is better to start your CH low (200-250)...when your water evaporates and you add high calcium water, your CH will rise. When CH gets high, the only way to lower it is to exchange water.
