Pool stability
You may want to add a rope around it from the legs on each side just for peace of mind then correct the issue when u need to drain water. For what its worth i’ve seen many people have broken straps so as long as the pool & legs are level & not moving you should be ok until u drain & remedy it.
Reactions: gorcho
