We have an AquaLink RS 6613/6614 control center that manages our pool and spa equipment. I’ve programmed the Solar Heating to run daily from 9:00 AM to 5:00 PM, with the pool temperature set to 85°F. I’d like to confirm whether the solar heating system is functioning properly. We have a Pentair CVA-24 valve actuator to direct water to the solar tubes, and it appears to be working correctly (I’ve also tested it manually).
On the remote, I notice that the Solar Heating status toggles between “Enabled” and “On”. Could someone please explain what determines this status change, and how to ensure the system is set to function in the “On” mode? I’ve read a few forum posts mentioning Temp1 and Temp2 settings, but I don’t see these options on my Jandy PDA. I'm unsure how to locate or adjust them.
Thank you in advance for your help!
