Hey Everyone! I posted a week or so ago and am back again for some advice. I did a lot of reading about SLAMing a pool and decided to start since my pool had sat for over a year without anything being done and looked really swampy. So I followed the instructions and balanced the Ph and Alkalinity, then added CYA all based on pool math. We have a 28,000 gallon pool that we scrubbed and took as much debris as possible out before starting. Based on pool math, we added what it said we needed for chlorine and kept the levels up above 10 ppm for the past week based on test strips (I know- not reliable, but I ordered the TF-100 test after posting on this forum and still haven't received it). So, in the meantime, I brought some water to be tested at the pool store two days ago and got the following results:
FC: 11.19
Total Chlorine: 16.32
Combined Chlorine: 5.13
pH: 8.2
Alkalinity: 132
Hardness: 148
CYA: 34
Iron: .3
Phosphate: 2965
I know that you all don't think the pool store results are accurate, but I'm just trying to work with what I have at this point until the test kit comes. So, based on this, I was told to add 8 more gallons of liquid chlorine, which I did two days ago (I haven't had the water re-tested since). I guess I'm wondering what to do next... the pool went from a deep green to a light murky green/brown, but I haven't seen any real change in color or cloudiness for a couple of days now. Its been 7 days since we started and I thought we would maybe see more change by now. Should I change the sand in the filter? Just Keep adding chlorine? Add something to reduce the iron levels in case that is what is making the water murky? Sorry for the long explanation, but I am at a loss and appreciate any and all help! I also attached a current picture of the pool in case that helps.
FC: 11.19
pH: 8.2
Alkalinity: 132
Hardness: 148
CYA: 34
Iron: .3
Phosphate: 2965
