I need to start taking pictures of the water each time I test the levels or do maintenance. I quickly forget the specifics of how it looked once a day or so is past. I think the water appearance didn't change much overnight Sunday. Monday morning I had FC 10.5, CC 0.5. Added ~10 oz of 12.5% bleach and went to work. 10 hours later (sunny day) FC had dropped all the way to 6.5 and the water appearance quality had degraded noticeably. Very green and very murky. Bottom definitely not visible. I got FC back up to 12 and brushed the walls. Water appearance has stayed the same since then. Visibility is about 18-24 inches down, then too murky to see anything. I have a few thoughts/theories, and a number of questions, after reading through a number of other threads on this site over the past couple of days, as well as watching a video my wife just sent me a short time ago.
My filter not getting clogged up as quickly is good news, but it is taking forever to get all the algae out. I'm wondering if now that the particles are smaller if it's getting clogged up without being clogged up. Let me explain...the water throughput is not clogged up, but the filter's ability to trap any more particles of anything is severely impeded...so water is pushed through efficiently, but no more particles get captured and they pass on through with the water. When I take the filter out now to clean it it's not as filthy visually - in other words, there are more areas that appear to be white or white-ish at first glance than previously - but perhaps there are tiny particles that are stuck to those sections that don't really show up color-wise but still prevent that part of the filter from capturing any more particles. Is that possible?
In one thread that I read, the pool owner lamented that he/she was getting so frustrated at watching all the little bits of green algae shooting out through the return jet when vacuuming. They "solved" that by upgrading to a sand filter. I don't know that I can afford a sand filter right now, but if I somehow could, would that likely speed up this process quite a bit? I can relate to that person's experience of watching the green matter shooting out from the return jet.
In another, someone that I've deemed to be reputable from my time on the site (long-time user or staff member I think) said to not forget this basic fact: filters don't kill algae; chlorine kills algae, then the filter removes it. That makes sense to me. I'm under the impression that algae is only alive when it's green. If both of those things are true, then why am I only seeing green (apparently) matter on my filter each time I hose it down? Is it capturing some live algae? Does it take quite awhile for the algae to turn brown/tan once it's dead, so it still appears green on my filter even though it's dead by that time?
Just read another thread where someone mentioned the need to brush and vacuum every day during the SLAM process. I realized then that I've not been doing that. I've vacuumed a handful of times, and brushed a handful of times, but have only done both on the same day once or twice that I can recall. Could the lack of that consistency explain why this is taking so long?
Finally - for now, at least - what would be the reasons to
not try this guy's advice in
this video that my wife sent me a short time ago? Aside from bleaching the liner, I mean - our liner was already bleached when we bought it used, so no worries there. If you don't want to watch the video - it's kind of long - he's basically saying that you need to hit the algae super hard all at once, just like you would hit a house fire. If your house is on fire you're not going to put out the fire in the kitchen one day, then tackle the living room the next day, and so on - you attack it all at the same time as much as possible. I don't recall how much chlorine he suggested but it would be way more than SLAM levels. It goes against TFP principles, I know that - but I'm tempted to try it if only to see what happens, because I'm spending sooo much time on this thing with very little apparent progress. The water appearance quality degradation the past 2 days really has me discouraged.
