POol sefety net. WaterWarden.
Slashdotjeo
4
Miami florida
Hi guys. I have an L shape pool. 15x32 with a 4x6 sunshelf creating the L shape. Would a safety net with a center tensioning system work on an L Shape pool with no deck. I only have grass around the pool.
It will pass inspection. I meant will this type of system work with my pool layout. I'd hate to drill all those holes and for entire system not to work. If you see the drawing, my concerns are with the L shape sunshelf. If I tighten the tension will it work across the net? Referencing my drawing, the yellow dots would get the tension leaving the purple dot side without tension. IMG_20220907_105741.jpg
Run it by your inspector. He is the one who will decide.
If it passes inspection it should work.
I don't see how the Inspector will pass something that does not work.
