I’m not sure why it’s blank, odd.Do you have a salt water generator? Your signature is blank so we can't tell what equipment you have.
Under your settings section, there is an area for general profile info (city, type chlorination, etc), but then there is a separate field for "Signature". That's where you will enter all of that info. If you still have trouble finding it let us know.I’m not sure why it’s blank, odd.
That's fine, but that link provided above still has several inspection points that apply at the equipment pad from the pump backwards into the ground where the drain line connects at the pad. Be sure to inspect all of those areas well as air can get pulled into the smaller spot.All water is being pulled from main drains.
This is the only return doing this.
Skimmers have been both shut off trying to find a leak in the pool.Hi KD,
Is your skimmer clear of debris? Is the pump basket clear of debris? What is the water level in relation the the skimmer mouth? Do you see air in the pump basket? What RPM is your VSP pump running?
