I have a newly re-plumbed and plastered pool. In my old (circa 1958) in-ground pool, I had only 1 copper return. The builder just now put in all new PVC including new skimmer, main drains, vacuum port and 3 returns.
I need to raise pH so I need to aerate. I'd like to know how these return jets work. There is no eyeball or directional piece. There appears to be a cover ring with 2 little tabs which makes me think the ring is threaded on and I can twist it off and reveal threads that an aerator can screw on to. Take a look at the pic and see if you recognize it and can recommend an aeration product.
(Sorry about the picture quality but it is taken thru the water from above.)
I have no idea of the manufacturer / brand of the returns but I'd like to find out what options there are to add aeration to them and then later to direct them downward after I fix pH with aeration. That's probably 2 separate items, I would guess? Thanks!
