I'm in the middle of a pool renovation, with new plaster, tile, coping installed. I'm waiting a month for the plaster to cure, and the plan is to pour the concrete deck after the plaster cure.
7 days into the startup I noticed a wet spot in the dirt behind the pool. I had the pipes pressure tested during the renovation when the deck was demoed so I knew it unlikely to be the piping. I had the pool renovator trench up the wet area and he found the leak coming from an old electrical pipe into the niche. He plugged up the pipe with an expanding pipe plug and said that would last the life of my ownership with the pool.
Before the pipe was plugged, I was losing 2.5" overnight. After the pipe was plugged, I am still losing a bit over 0.5" overnight. I did a tiny bit more trenching and there is still a leak coming somewhere in the the niche shell (concrete or otherwise, hard for a layman like me to tell).
I know for sure the leak was not occurring before the replaster job - pool was holding water perfectly for the months before we drained it for the reno. The pool builder talked with the crew and they cleaned out all patchwork inside the niche during the prep work. He says the niche was plastered on the inside and that was what was holding the in water before. His crew cleaned out that plaster but didn't reseal anything or check for anything (I caught him chewing out the crew lead).
I'm being asked what path I want to take:
I want to be reasonable, but I think this should have 100% been addressed when the pool was empty just a week ago. He could have raised the concern about the niche then, and I wouldn't be in this conundrum. We already replaced the autofiller, the skimmer, upgraded the drain to a dual channel (for safety), and I also paid to replace the pool light.
I know I'm a new member, but any advice would be greatly appreciated.
- Have the pool builder put a bandaid on the current niche like was done before (they plug it up on the inside with silicone, plaster, or otherwise). Risk I run is they do this, I pour a very expensive deck, and whatever they patch it with fails.
- Replace the niche. If they replace the niche, they will have to drain the pool below the fixture, chip out the very expensive pebbletec plaster, install the new niche, and very likely have some apparent difference on my brand new plaster. My deck will have to wait even longer because they would have to trench out to place the new niche. This work wouldn't even start for another 6-8 weeks from today because the plaster still has to cure (as per the plaster company). If I wait for this, he won't plug up the current leak as he says it's not going to cause any issues with the ground or any surrounding area.
