Hi TFPers,
Still in the marketplace to have our pool resurfaced. I have some questions with regards to the main drain and our 1 pool light.
Main drain
We have a kidney shaped pool with one main drain. Most pool contractors/companies have quoted converting the main drain to a channel drain, and only one suggested replacing the cover with a VBG compliant dome-shaped cover. The later suggested that because due to the irregular shape, a channel drain would look odd because it would not "line up" with anything. Also, if I recall correctly, I think the pool contractor stated something about my 1.5 hp VSP Hayward Maxflo may not have enough power or something for a channel drain (maybe I completely misunderstood him b/c I don't see how my pump wouldn't work with a channel drain). The other pool contractors never suggested a dome shaped VGB compliant drain cover, rather the only option was the channel drain.
I called the City of Livermore to verify a permit is needed for this remodel, and to discuss the main drain. They stated that the drain has to be VGB compliant. So, I am not sure if that means it has to be a channel drain or it could be a dome shaped VGB compliant drain cover.
My questions are:
1. Which will look better and function better... channel drain or a dome shaped VGB compliant drain cover?
2. I use a Maytronics S200 robotic cleaner, which I read could intermittently get caught up on the dome shaped cover. Can anyone substantiate this? Is this an issue enough that I should consider the channel drain instead?
Here are a couple of links of what I could find at Amazon for channel drains:
https://www.amazon.com/32CDAV101-Anti-Entrapment-Channel-Drain-3-Port/dp/B004UHF0P4/ref=sr_1_81?s=lawn-garden&srs=9479744011&ie=UTF8&qid=1516046950&sr=1-81
Amazon.com : AquaStar MoFlow 12-Inch Square Retrofit VGBA Anti-Entrapment Swimming Pool Drain Cover - R12MF101 : Garden Outdoor
As for robotic cleaner hang-ups, I had read here at TFP (Doheny's Discovery, S200, Active20, Triton owners club) that some people suggested using this cover:
https://www.amazon.com/dp/B002SG7NQI/_encoding=UTF8?coliid=I3HKBUXNL16LH9&colid=2YLR2FXPFHZZA&psc=1
Pool Light
We have one pool light. We pretty much never use it now, but in the future as our twins age, I anticipate swimming at night and the light being used. Thus, my wife and I would like to replace the light to a LED. The quotes I have gotten from these pool contractors/companies to replace this range from $600-900. Less for a white LED light and more for a multi-color LED light. Then, some of these contractors have stated that I could even spend more (~$300) for a multi color pool light that I can remotely control. The $900 was for a multi color LED that goes through the color spectrum but could be manually overridden by flipping the light switch up/down to stay on one color. Lately, for pool surface, we are leaning towards going with a small rock aggregate (e.g. Wet Edge Satin Matrix, Pebble Sheen, or Adam's Pool Solutions Super Mini Pebble) in a sapphire blue, which would be akin to a sky blue or light blue. We have thought just a white LED would look good, but I have considered if a few hundred more for a multi-color changing LED would look good (the $900 option).
Questions:
1. When would you go with a white LED vs. a multi colored LED light? Which one would you use in this situation?
2. Another TFPer suggested looking at INYO pools for retrofit LED lights. Perhaps I could buy what I want and the pool contractor will install it. Which lights and types would you suggest.
Here a couple pics of my current main drain, and pool light:
As you see, what would a channel drain line up with?
Single main drain, single pool light, with Ghostlight, my Maytronics S200
Main drain
My questions are:
Pool Light
Questions:
