ckendalls
- May 17, 2018
- 130
- Plaster
- Hayward Turbo Cell (T-CELL-5)
You will be adding bleach much less frequently as soon as you get the chlorine stabilizer Cyanuric Acid (CYA) in your pool. Since your are just starting you could use liquid stabilizer. One bottle should get you to 40ppm + . It will also drop your pH so do it when your pH is up. You can get more dry stabilizer as well but this dissolves slowly and is best added in a tied off skimmer sock hung in front of a pool return rather than into a skimmer basket.
Amazon link for liquid stabilizer (mix shake well) its a slurry and you will refill the bottle with pool water to get it all.
Amazon link for dry stabilizer
It will take the water a while to stabilize, but the CYA will also help. My water stabilized pH wise when the TA got down to 60 and less acid is required particularly without a SWG chlorinator.
Enjoy!
Enjoy!
