Pool Pump Timer Wiring Help
Hi all! I hope a post like this is okay. I have general knowledge of electrical wiring but wanted some advice. I recently purchased a home with an inground pool. The pool is set up for salt water with a generator on a separate circuit from the pump. I would like to set up a timer for the pump and the salt water generator but I am unsure if I can get away with one timer or if I need a timer for each system. I have attached some pictures of the set up as it is. Any help would be greatly appreciated. I have already ordered a timer for the pump link below. I think I can get a larger 40amp breaker and run to 1 timer and then run 2 lines out (1 to the pump and the other to the SWG)
Top breaker is pump and bottoms is SWG
