Pool pump question
Dima
0
May 21, 2014
49
Brampton, Canada
Good day, I have 1HP HAWARD pump and I noticed the water flow is really bad . Pump been running for a 2 years in my above ground pool. Couple of weeks ago, my kid was able to manage let it run dry for about an hour. Would that can caus the damage to it ? I can understand it it does not work at all, but it looks like working but not enough flow compare what it used to be. Or maybe should I look at something else ?
Thanks!
Have you checked your filter pressure? When was the last time your backwashed the filter? Does the water return have air bubbles in it?
