Hi, all—I installed a new pool pump motor this past fall and it’s been working great. Today I went out and noticed the water had dropped significantly. Upon inspecting the equipment, sure enough, the motor housing was dumping water out. I’ve refilled the pool.
I’ve taken the motor off of the housing and inspected the o ring and ensure the impeller is spinning. Those seem to be fine. Honestly, I’m not sure what it is. The impeller/diffuser weren’t replaced when I replaced the motor, so it could be those. And if I replace those, I may as well replace al of the o-rings again. Thoughts?
Here’s the model:
Here’s a video:
Here’s the model:
Here’s a video:
