- May 3, 2007
- 17,029
- Plaster
- Hayward Aqua Rite (T-15)
OK, I did a bit more work on this and came up with two plumbing scenarios. Best case (1/2 the fittings and 1/2 equipment loss) and worst case (same fittings and equipment as my pool). I also added a 3/4 HP Northstar pump vs the 1.5 HP Superpump which both have the same BHP and thus about the same energy use. Here is a chart showing the results.
NS is Northstar
SP is Superpump
You can see even the 3/4 HP Northstar pump would work for your plumbing although the best case would be close to the flow limits. With this hopefully, it will help you make a decision on what to do next.
You can also see that the Northstar provides more GPM and Head loss for the same input power (BHP).
NS is Northstar
SP is Superpump
