Hello I have an above ground and I am having issues with my sand filter. I loose pressure after a couple of hours. There are no leaks and I took motor apart to clean impeller. Skimmer basket clean and hoses are clear. I’m dumbfounded. HELP!!
Welcome to TFP!!!Hello I have an above ground and I am having issues with my sand filter. I loose pressure after a couple of hours. There are no leaks and I took motor apart to clean impeller. Skimmer basket clean and hoses are clear. I’m dumbfounded. HELP!!
Just opened pool a few days ago so all chemicals are in the high side right now plus can’t circulate water correctlyWelcome to TFP!!!
Do you mean a couple hours after you backwash?
Losing pressure is a sign of a chemistry problem (algae). How are you testing your water? Can you post a full set of test results?
Also it’s on filtration mode when this is happening.Just opened pool a few days ago so all chemicals are in the high side right now plus can’t circulate water correctly
