I have a few questions about the plumbing of my pool. I inherited the pool when I bought the house, and the previous owners are not knowledgeable.
See the drawing of my theory on how this pool is plumbed, but I am absolutely NOT certain of of this.
IG vinyl 16x32 pool. I have a sand filter, two return jets, a main drain and one skimmer. Just to the pool side of the inlet to the pump is a ball valve. Inside the skimmer are two holes in the bottom. I *believe* that the hole closest to the pool is the line feeding the pump (suction side, since that's pretty obvious when the pump is running), and the hole furthest from the pool is the inlet from the main drain. This is the part that I'm not sure of.
Attached to the bottom of the skimmer is a "diverter" assembly that has both a valve and a flap that can swing into position to block of the flow of water from the water line of the pool into the suction side of the skimmer entirely.
The way the pool seems to work best is to turn the diverter valve inside the assembly in the skimmer to a 45 degree angle, and move the top flap so it is about halfway covering the top port. In theory, that means I am pulling water equally from the main drain and the water line into the skimmer.
The questions I have are:
1. Why does the pump get completely starved of water when I turn the valve in the diverter so it is horizontal and close off the top flap? Based on my understanding, this position of the diverter should be sucking 100% of the water from the main drain, but the pump is almost immediately starved and no water comes out of the return jets.
2. Why does the pump get completely starved of water when I turn the valve so it is perpendicular and open the top flap completely? This is how I should be able to generate maximum suction for my vac hose, for example. It simply does not work. Is there something I am missing in order to generate maximum suction for my vac hose?
3. How do I winterize the pool with this type of setup? I'm specifically referring to the main drain plumbing when asking this. Do I blow air into the "main drain" side of the skimmer until air bubbles up from the main drain at which time I can plug the port and create an "air lock"? Water line would be below the skimmer during this operation.
Thanks for any advice or guidance.
