Hello! I installed a new autopilot and I cannot get the screen to come on. I installed it on 120v (switched the plugs and the fuse out) and when plugged in, it won't display anything on the screen. The check system light does come on and is blinking. I have checked the fuse which seems okay, checked to make sure the screen board is plugged into the unit, and nothing seems to be corroded or blown. It is a brand new unit which has never been installed. The model number is 75041A and the serial number is 211100708. The cell is a PPC1, also brand new. The pump is plugged into the same power source and is working with no issues, so I know its not the power source. I've tried unplugging the pump and the unit screen still will not power on.
Any other ideas? I don't know where the unit was purchased and I do not have the purchase date, so I'm not sure if I'll be able to use the warranty.
