- Aug 8, 2024
- 274
- Plaster
- Pentair Intellichlor IC-60
The pool plumber is saying to just add a T and a few ball valves. I’m going to swap all of my street 90s and regular 90s out for sweeping 90s and figure it’s a good time to add a heater bypass valve.
Photo below gives an idea of the setup.
Do you guys recommend buying an application specific bypass valve or am I okay to add the ball valves and then crack one open to allow 10%ish flow through the heater at all times or should I drain and blow out the heater somehow and let it sit dry until the months we use the heater?
Thank you for any advice,
Donnie
Donnie
