This is a total mystery to me because I don’t know how this can happen with what seems like a very simple drainage system.
I have a vertically orientated PVC pipe within an enclosed cutout in my deck which my pool water runs into from a bottom access hole. When my water level gets higher than this PVC pipe, the water simply runs down the tube and drains into my yard. Simple enough. My water level can stay stable right near the top of this tube for days. But if I get a heavy enough rain one night, I’ll wake up and the pool has over-drained to the point where the water is 2 inches below the top of the PVC pipe. This usually occurs to such an extent that my auto-fill turns on to add fresh water.
My question…how can the water possibly drain beyond the top of the PVC pipe? Since a moderate rain can allow my water level to increase to the very top of the drain pipe and remain stable for days, I dont have a leak. It’s only when I get enough rain to force the water level over the tube with a heavy rain does it then over-drain and drop too low.
My short explanation here is probably not enough for an obvious answer, but thought I’d throw this out there in case someone has had a similar issue.
The only thing I can think of, is it has something to do with the plumbing where my drain tube is located, so I’ve included a picture from above. The access hole where the drainage pipe is located is somehow plumbed into my nearby skimmer hole with the intent to naturally maintain similar water levels - I assume.
Thanks in advance for any thoughts or advice.
Bill
Bill
