Ok this may be a dumb question, but I want to make sure I'm doing things in the proper order. Last season (our first summer) we had the pool opened for us. This year with our pool renovation I'm doing the opening myself. We had swim ready pool water trucked in to fill our inground gunite pool. Pump issues aside (posted in the other topic). We have a sand filter. There are two Jandy style valves that close and open the lines from the main drain and the skimmer (suction side).
This is the process as I understand it.
Remove plugs from jets and skimmer gismo/ice compensator.
Return skimmer basket.
Fill the pool to the proper height (middle of skimmer box).
Reinstall drain plugs in pump/sand filter.
Reinstall pressure gauge and sight glass on sand filter.
Set sand filter multi-port valve from winterize to filter
Turn on the pump
once a steady stream of water is flowing out of the sand filter's air relief valve, shut the valve and we're good to go.
Before priming or turning on the pump I opened both the drain valve and the skimmer valve. Is this correct or should I keep the drain valve shut unless I need to set my sand filter valve to waste? I'm not 100% sure when to have the drain valve open and when it should be shut. This is probably a dumb question but we're still learning here.
Turn on the pump
