For crying out loud. My problem is a contaminated cylinder.
Last night by accident, I used the wrong graduated cylinder. FC was as ithas been for weeks, CC: 0. So great I’m done, I’ll shock & do the sunrise test.
Sunrise test: used the proper graduated cylinder. FC holds, CC: 1 & I think no way-, the water temperature is < 70F, super clean & looks it great, blab la bla.
For the heck of it, I test with the "wrong" graduated cylinder, CC: 0
I assume you want me to fill the proper contaminated cylinder with bleach & let it sit an hour or so ? Or just as few minutes full of bleach should do it, right?
Or is the plastic shot & it needs replacing?
Of course the next FC & CC test I run I’ll again be using
both graduated cylinders to verify. But I always assumed there was a reason the proper graduated cylinder says “chlorine only†on it & it makes sense to keep graduated cylinders dedicated to certain tests.
After testing, I always rinse the proper graduated cylinder in tap water multiple times then shake it dry & back into the case. Should I be drying it? Before testing it is always rinsed 2 times in the pool & the 3rd time is my sample.
I’m cursed. I haven’t read about this problem anywhere on TFP. I have to believe it is the tap water residue from not totally drying it prior to storage; unless you guys tell me the plastic is shot.
The “chlorine only†graduated cylinder is not as clear/clean-looking as the others- which look new. I’ll let you know if the appearance changes or not after bleaching it if that is what you guys advise.
Bummer, wasted a lot of chemicals & reagents & pump time & my time & moderators' time on this one, still quite cool here, balancing should have been a snap- major bummer.
