This is my daughter's pool. They moved in and the pool was already dark green - because of "life" they didn't open it last year. I want to help them but not sure where to start. I follow this site for my own pool but haven't every started from this point!
Water is pretty cheap - the pool is vinyl and about 25,000 gallons (16 x 32), 1 skimmer, no chlorinator, sand filter. Here are my thoughts - does this make sense?
Drop the water level right below the skimmer returns using a sump pump or a siphon.
Refill with fresh water.
Brush a lot.
Drop the level again. (Do this a few times to start to replace some of the brackish water)
Turn on the pump (hasn't been started in 2 years but was replaced in 2017 per previous owners.)
Bring up the CYA which is now 0
Adjust PH (not sure of this but will lend her my test kit)
Once CYA is measuring and PH is in range - start the SLAM process?
Is this the right order? And how do we get all the gunk off the liner bottom. You can kinda see the top stair - nothing else. Might be alligators in there for all we know. Thanks for any advice.
Brush a lot.
