- Mar 13, 2022
- 58
- Plaster
- Hayward Aqua Rite (T-15)
Pool motor: Century HST080, 0.8HP, 2.5yrs old
Pump: Hayward SP
Test kit: TF-100
Pool Size: 18500 gallons
To start off, I just want to say that it is most likely my fault as the water level was low to begin with.
This happened yesterday. I tested my water and ph was high so I poured Muriatic acid to bring down. Main drain valve was on and so was skimmer valve ( it can be adjusted by manually turning valve to work with independent vacuum Sunction line). I went outside and noticed motor was not running or making any sounds or burnt smells. So I turned off and on back again and nothing. I filled pool with water. I cleaned vacuum basket and strainer basket. Noticed that there was no water on strainer. I filled strainer with water and tried turning back again, but motor not priming. I stuck a clothing hanger on impeller to see if anything was stuck but it was free, but impeller fan was hard to turn. Is the motor faulty and need to buy a new motor? Bad capacitor ? Should I remove motor and try to clean impeller ? Anything else I can do? Clogged line.
After I cleaned baskets and filled with pool water motor sounds like it is running and no burnt smells, but not priming. I have attached some photos my setup and motor.
Pump: Hayward SP
Test kit: TF-100
