Hi all!
I'm in need of a pump motor replacement (current one is whining), and I just want to get some help on an appropriate choice.
Pool size: ~15000 - attached jacuzzi with 4 jets
Run Time: ~8 hours
Variable speed required (here in California)
Current motor is the VS-Green 270 - 2.7 max HP: Info
Based on my understanding of pool school, I'll need 1.3~ HP to run the 4 jacuzzi jets. I assume the pool jets don't require that much HP.
I'm currently looking at the following motor as a replacement: Century 1.65 HP motor <-- (not available in California, but consider the specs)
ETA: I had just changed the seals and gaskets because the pump was leaking. Motor was relatively quiet before change, but getting a bit louder. Not sure having the pump out and in the dry could have sped up its failure.
Run Time: ~8 hours
