- Nov 28, 2020
- 269
- Plaster
- CircuPool RJ-45 Plus
First off, I paid for a premium subscription for the Pool Math app. Then I logged into the app with my TFP forum credentials. Now it says to subscribe for unlimited test logs. I am assuming the one premium subscription will be good for all my devices? How do I sync them so I have the premium subscription linked to my TFP account, and on multiple devices?
Now, I used my Taylor K-2006 for the first time today and this is what I came up with:
FC 7.8
CC .04
PH 7.5
TA 140
CH 360
CYA 84
Borate 20 (from test strip)
Pool Math is recommending a significantly higher chlorine level due to the high CYA, and my borate is very low. So I am thinking the first things I should do is lower the CYA significantly through partial draining and refilling, then bring the borate level up and balance the expected Ph swing, then re-test the water and get alkalitinity in line, then balance the chlorine. Does that sound like a good plan? Also I think my water is already hard but within ok range, but Pool Math is telling me to add calcium chloride to make it harder, if I am not mistaken. Not sure if I should do that.
FYI, from a water test from the pool store two days ago (I had almost zero chlorine at the time) it showed:
hardness 231
TA (w/stabilizer correction) 86
CYA 87
copper .1 ppm
iron .2 ppm
borate 15 ppm
My pool is plaster/chlorine 11.7x40 ft avg. depth 4.5 and calculated 15,600 gallons. Also here is a read only link to a google spreadsheet I started today with test results: Pool Maintenance Murlesan
Thanks in advance for the guidance.
FC 7.8
CC .04
PH 7.5
TA 140
CH 360
CYA 84
hardness 231
CYA 87
copper .1 ppm
iron .2 ppm
borate 15 ppm
