- Nov 7, 2018
- 1,049
- Plaster
- CircuPool RJ-60 Plus
On the web version of Pool Math, there is the following wording under the pH measurements:
Can someone clarify the underlined portion? I would think it should say "...is at the top OR bottom.." because I can't really make sense of it any other way. I attached a screenshot for specificity.pH calculations depend on TA and Borate. Results are approximate and can be off significantly for large pH changes. Changing your pH will also change your TA. Users should be very mindful of their CSI when their pH is at the top of bottom of the suggested ranges.
