Pool Math App/ Effects of Adding
wmarq
122
Tyler,tx
Hayward Aqua Rite (T-15)
Good morning ,
I am sure that I a missing something so I am just putting this out there to get a little clarification. I'll post the pictures but how much acid do I need to add here to go from 8.0 - 7.6? IMG_4661.pngIMG_4660.pngIMG_4659.png
thank you !
I found this in the similar threads suggestions below my post from @ajw22 that comes up after you post! LOL I should have looked a little harder before I posted I guess. Sorry about that and thx again....
effects of adding does not consider your TA while the main page target calculation uses the TA value.
That said, all the pH adjustment calculations are approximations and the larger the adjustment the more it can be off. Small adjustments of reducing the pH by 0.1 to 0.3 is pretty accurate. Once you get larger adjustments of 0.4 and more the pH calculation gets a wider error range.
Bullfeathers !!!
If nobody asks anything, we all show up everyday with nothing to do and folks will stop showing up. So THANKS for keeping my people showing up. :)
Reactions: wmarq
