- Jan 30, 2023
- 113
- Plaster
- Pentair Intellichlor IC-40
I'd love to limit my pH drift by dropping TA to 60, as this approach was worked very well in my spa. However, I find it challenging to get the right mix of other levels in Pool Math that result in CSI around -0.15 (midway point of 0.0 to -0.3 target range). Here are my preferred targets:
TA 60
pH 7.6
CYA 70
CH 450
Salt 3400
BOR 40
Water Temp 80
However, at these levels, my CSI is -0.37. If I drive pH up to 8.0, I get CSI to my target at -0.14 but I feel like I'm right on the edge with pH, as my understanding is I never want it to exceed 8.0. I could push it to 7.8, but that leaves CSI at -0.24, resulting in both pH and CSI a bit closer to the edge of my acceptable ranges for both. Am I missing something? My SWG calls for 3,400 as the ideal. CSI is relatively insensitive to BOR levels. Not much room to play with CYA given recommended 60-80 range. There is some ambiguity on TFP re: acceptable CH levels (the ABCs of Pool Chem calls for 250-650 but the sticky TFPC for Beginners calls for 200-400), but even if I pushed CH up to 650, I still end up with CSI of -0.21.
Appreciate any guidance!
TA 60
pH 7.6
CYA 70
CH 450
Salt 3400
BOR 40
Water Temp 80
