- Jun 3, 2020
- 108
- Plaster
- Jandy Aquapure 1400
Hi All,
We've been using TFP methods with our pool since it was opened 9/2020 and have always had wonderful water quality, thank you!
With short notice, we've decided to go on a two week vacation and we're thinking about how to handle the pool while we're gone. No one in our area has a pool and we are not comfortable asking those without chemical knowledge to handle acids for us so we have to figure out how to leave it and hope for the best. Three questions for any experts out there on Pool Math, PH, and unattended chemistry levels...
With a SWG, the chlorine often self manages (other than when the cell stopped working recently). My spouse adds (everything but most frequently) CYA & MA when needed based on Pool Math. We tried doing some analysis with the data out of the app; however, we did not see how to export the logs for when he added chemicals in order to do a regression analysis to calculate reliable projections for the water quality at any given time based on the numbers the day we leave.
Question 1: Does anyone know how to export both the logs and the maintenance at the same time?
Based on some simple averaging, it appears our PH goes up .1 per day without us adjusting anything. If we take it down to 7 the morning we leave, then by the time we get back (15 days) it should be ~8.5. As long as the FC is maintained by the SWG, and is protected somewhat by CYA at the upper limit the day we leave, then I think we are fine with that and plan to add chemicals the day we return. I noticed several threads where there was a suggestion to slam the pool before leaving; however, we're uncertain about doing that when our PH requires management to bring it down. Turning up the aquapure or adding liquid chlorine always raises the ph so we'd have to put far more acid in to do that. Question 2: Is it really necessary to slam the pool before a trip?
Finally, we have a Catch a Kid Net we put over the pool when not in use. Several threads indicated that covering the pool while we're gone might help with chemistry. Is it worth going through the trouble of finding something on short notice that will go under the CAK? Question 3: find a cover or leave open?
Here are random items in case they help with answers:
All the best,
Darla
Manually created table of MA added this year:
Recent Pool Logs
Snoopy
Build Type: Plaster
Volume: 19500 gallons
Latest Test Result Summary:
FC: 8.0 (an hour ago)
CC: 0.5 (an hour ago)
pH: 7.5 (an hour ago)
TA: 60 (an hour ago)
CH: 475 (an hour ago)
CYA: 80 (an hour ago)
SALT: 3600 (an hour ago)
TEMPERATURE: 86° (3 days ago)
CSI: -0.35 (an hour ago)
Test Results 05-08-2022 @ 10:09 AM
Free Chlorine: 8.0
Combined Chlorine: 0.5
pH: 7.5
Total Alkalinity: 60
Calcium Hardness: 475
CYA: 80
Salt: 3600
CSI: -0.35
Chemical Addition 05-05-2022 @ 02:03 PM
+ 6 Pounds of CalciumChloride
Test Results 05-05-2022 @ 01:48 PM
Calcium Hardness: 400
CSI: -0.47
Test Results 05-05-2022 @ 01:44 PM
Free Chlorine: 6.5
CSI: -0.59
Test Results 05-05-2022 @ 01:42 PM
pH: 7.2
CSI: -0.59
Test Results 05-05-2022 @ 01:41 PM
Salt: 3600
CSI: -0.02
Chemical Addition 05-05-2022 @ 01:36 PM
+ 4.5 Pounds of DryStabilizer
Test Results 05-05-2022 @ 11:00 AM
Temperature: 86°F
CSI: -0.44
Chemical Addition 05-04-2022 @ 01:00 PM
+ 40 Pounds of Salt
Chemical Addition 05-04-2022 @ 12:59 PM
+ 0.5 Gallons of Baume31
Test Results 05-03-2022 @ 11:44 AM
Free Chlorine: 5.5
pH: 7.8
CYA: 50
CSI: -0.01
Chart of FC & PH over the last year. Dip to 0 in April of this year was when aquapure stopped working properly for about a month.
- We are in a location where the pool is very hot and in full sun this time of year (water temps up to 93 if we don't manage it and we won't be here to do that)
- No fountains or bubblers are running (they've been on ~4 days this year). It is used by a splashy kid several days a week; however, no splashing will occur while we're gone
- Since we're entering the time when there is more sun on the pool and more use of the pool, we've turned up the aquapure which drives up our PH (even more than our plaster brings it up). Right now, we're adding .25-.5 gallon 31.45% MA every ~10 days.
- Our pool is set for auto-fill on city water that has been tested at PH 7-8.7, TA 27.4, Chlorine .86-1.48 ppm (should not get much fill during this two weeks)
All the best,
Darla
Date | Volume | Measurement |
4-May | 0.5 | gallon |
24-Apr | 0.25 | gallon |
21-Apr | 0.5 | gallon |
4-Apr | 0.5 | gallon |
13-Mar | 16 | oz |
16-Jan | 32 | oz |
Recent Pool Logs
Snoopy
Build Type: Plaster
Free Chlorine: 8.0
pH: 7.5
CYA: 80
Salt: 3600
CSI: -0.35
CSI: -0.47
Free Chlorine: 6.5
CSI: -0.59
pH: 7.2
CSI: -0.59
Salt: 3600
CSI: -0.02
Temperature: 86°F
CSI: -0.44
+ 40 Pounds of Salt
Free Chlorine: 5.5
pH: 7.8
CYA: 50
CSI: -0.01
