I have the cursed pool... 4 years and I'm my 3rd set of pumps and filters and still no clean pool.... my suction isn't the greatest but it gets to be almost obsolete after running filter for an hour or two.... I just replaced the pump with a new 1.5 horsepower pump and just change the sand in my filter and I'm still having issues.While changing the sand I noticed broken laterals. I had my other filter still that was barely used so I replaced my standpipe and laterals with the other ones. The filters were not the same size or brand but they are in good condition because that filter sprung a leak shortly after purchase. Would that be causing problems???? I have changed the PVC pipe three times to be sure there are no leaks..... the pool has great pressure when it's running on recirculate... when it's on filter it runs for a while and then loses pressure so I backwash and rinse and then it regains its pressure... but slowly loses it again. my multiport valve is a little troublesome but would that cause priming issues??
I'm at a loss at this point... I don't know what to do....
is it the laterals or the multiport valve?? should I replace the filter?? or is it something else ??
