We have an in ground pool. I had the light apart once and I believe it is a standard 120V screw in bulb.
Last year we had the linear replaced and they replaced the light. This spring I turned it on and it worked. the next time I turned it on...nada.
It's not like we had the light on all the time, I'd guess probably less than 10 hours total usage. A couple questions.
Is it normal that these lights don't last that long?
I would like to have one of those cool multi color ones that I could change colors and patterns but the last time I checked into this there where not many options unless you wanted to replace the wiring which I definitely do NOT want to do. Are there any neat options out there for this these days? Do these LED bulbs last any longer?
Finally is there anything I should be looking for that would cause the bulbs to not last very long? Obviously a leak would be an issue but I won't know that until I pull it out...and the water temp is 62 degrees so I'm not jumping anytime soon to pull the bulb.
Thanks
Thanks
