So I went out and removed the old circuit breaker, black extension cord piece, and GFCI outlet to get a head start on things. Took some pics so you could see with a little less clutter now.
I do have a couple questions now that I can see a bit more clearly --
1) There is what appears to be a neutral bar located directly underneath the timer, which didn't show up as clearly in the other pics, cause I wasn't looking for it specifically (better pic below). All the current white wires are connected to it (like the timer and that loose GFCI outlet). Should I connect all the white wires to this, instead of connecting them all together and capping with a wire-nut like the diagram shows?
2) Some of the wires from the PLW01 go into another little receptacle I don't think we've talked about. From the info you've given me, I assume this is wiring for the home automation stuff? I can just remove those, right? BTW --- you can see the little clear plastic piece half-falling out of the little box.... it was painted over the same brown color as the walls, I pushed on it a bit to see if that was a release mechanism... but once it fell down a bit, and I could see more then what was painted-over, I could tell it was obviously something else.
