Hi TFPers,
We want to upgrade our light to a color changing LED, since we are going to have our pool resurfaced/tiled. The pool contractors/companies want a ridiculous amount of $ to upgrade to a white LED (~$650), and then even more for a color changing LED (~$950). Add to that their sales pitch that I'll "get tired of using the pool light switch to stop or change the color light show" and instead would need a remote control color changing device to switch through the shows, that I have begun to research doing myself by way of Inyo Pools. Another member informed me about Inyo Pools Pure Colors LED series. So let me get underway.
I was informed my light was a Purex and I assumed a 500w, but I took it out of the niche today and took some pics. Yes, it is a Purex 100-5 by Underwater Laboratories. If I am correct, I think this is now considered a Pentair brand. Here are the pics:
Looking at this pic, does this rust/corrosion warrant replacing the entire light? At what point, should I consider replacing the light fixture vs. bulb?
From what I am learning at INYO Pools, I think I can just change the bulb. Any of you TFPers done it and care to chime with tips? I know I need to get a replacement gasket. We are also going to resurface our pool, and after much research, thought, and reflection, I have decided on going with either Wet Edge Primera Stone Tahoe Coast, Riviera Coast, or Caribbean Coast.
Top to bottom: Riviera Coast, Caribbean Coast, Tahoe Coast
Given that, would you all go back with the stainless steel face ring, or replace to a gray, white, or black plastic ring? This is based on being able to find a 10" OD and 6 5/8" ID, which is not proving worthwhile at least at INYO Pools.
INYO shows this for my Purex: THIS LIGHT IS OBSOLETE BUT MAY BE REPLACED BY A COMPLETE EQUIVALENT AMERLITE.
Purex CHD / Pool Star Light Parts - INYOPools.com
However, when I go to the parts list for the Amerlite, and click on the plastic face rings, I can't find a face ring matching my measurements. Thus, perhaps the current stainless steel one is good enough.
Lastly, my is wired for 120 v. Is it worthwhile and possible to convert to a 12 v? Is that worth the cost? That would be beyond my abilities/comfort level and I would have to hire out for that. Here is my current junction box.
