I have old Swinquip pool lights and the ring around the niche is rusted and staining the vinyl liner. They do not make them any more so I cannot buy new ones. So I want to remove them and have them cleaned, maybe sand blasted and then powder coated. Checking with a couple of local shops, this will take a couple of days.
So if I remove the ring, will a lot of water leak out during this time?
And if some water goes between the vinyl liner and wall, will it cause problems?
I think there are 8 or 10 screws holding the ring to the niche, so I was thinking after I remove the ring, if I use what is called fender washers (they have small holes and are bigger around than a normal washer) and put them in place with the screws there would be less of a leak, any thoughts?
