Hello,
My pool level dropped about an inch in a couple of days last week. We have not noticed leaking near the equipment at all. I did have a new Polaris pump installed and it did drop below freezing previous to leak. I filled the pool added extra bleach, put pucks in the pool and shut the filter off to see if it made a difference, it did not. We did have a leak once in summer, it was easy to detect, the ground was wet by the pool. We have gotten a lot of rainfall, the ground its wet everywhere. Also, we did have a stump ground about 18 inches or so, maybe the pipe got knicked and the freeze made it crack? How deep are the pipes suppose to be? He knicked our electrical pipe that was only about 3 inches deep. The hole is still there as we are fixing the pipe. We are going out of town, I am filling the pool again, no freeze in the forecast. Should I put the pump back on, I was afraid the pressure might make things worse. Adding water to pool again and suppose to go out of town for a few days, how should I proceed?
Thank you!
Thank you!
