- Mar 10, 2013
- 82
Hi guys, I've had an issue with my pool for a while, where every 2-3 days I need to fill the pool for about 45 minutes to an hour to bring it back to appropriate levels. The pool must be leaking, as it does not seem like as much water would disappear from normal evaporation causes. I have a pretty small sized rectangle pool, with a skimmer, and of course the pump and filter. I replaced the filter recently, but it did not change the leaking. It's a Sta-Rite Posi-Flo II, and running at 11 P.S.I. I do not see or feel any water leaking around the pump, filter base, under the clamps of the filter base, or from a pvc pipe. I have attached some pictures of my setup. Once I increased the pool level, there is not an air bubble in the container before the motor, like the picture shows.
Any advice would be greatly appreciated, as this has really stumped me!
