Hey guys. Question regarding return line repair.
Scenario: My pool water level was dipping so I suspected a leak. I marked water lines for a couple of weeks and noticed more loss with pump on versus pump off indicating return lines may be the issue. I walked around the outside of our concrete slab and noticed damp soil in one spot (we had a hot summer even for Texas standards so this was notable). Then I noticed the cement adjacent to the pool had been patched above where two return lines enter the pool and it looked like a prior repair job (we moved in a year ago). I dug out the damp ground near the slab trying to tunnel under to the pipes. I wasn't able to get to the pipes but when I left my pool pump on for 2 hours, the hole I dug filled up with water letting me know I was in the right spot. I rented a concrete saw and cut out the prior patch of cement and dug down to the two return lines. The one that was previously repaired looked good. The other had a leak from the 45 elbow connector (pic attached).
Question: I removed the leaking 45 elbow. The return line that I had to cut is full of water. I've let it drain and drain and removed multiple 5 gallon buckets worth of water but it keeps coming. The pump is obviously off. I want to make the repair but not sure if I continue to drain the line until its dry and I can make the repair in a dry field or do I make the repair with water everywhere? I have it capped for now. The pipe is 1.5" diameter and travels probably 80 feet or more back to the pump so there could be a ton of water that I would have to keep scooping out of the hole. Is there something I'm missing?
(Once I get the pipes are repaired, I'm planning to fill it back in with dirt and do the concrete work myself. I was quoted around $400-500 for leak detection and over a $1000 for all of the digging and repair.)
Thanks for any help,
Cody
Cody
