Hi all - I could use some advice. I had a company out to change the sand in my filter and immediately afterwards there have been cascading issues including, (1) a failed pool pump part literally a few hours later; (2) heating regulator stopped functioning within a day or two; (3) leaking from our Calorex dehumidifying unit (we have an indoor pool). (4) And now, most concerningly, it looks like the pool itself has sprung a significant leak. Ever since the sand change the pool has been unable to get to appropriate level. Upon turning the autofill off, I'm losing about half a tile per day.
The one thing I know the pool guy did wrong was that he failed to turn a valve during the backwash that protects the Calorex unit. When I first purchased this house I was told that there are two valves that need to be turned during backwash, and if the second one is not properly shut, then there will be massive pressure on the Calorex unit. This at least resulted in problem #3 above (backwashed water went into the unit and caused the pan to overflow for a few days after the sand change).
However, now I have a pool leak. Is it coincidence? The pool company says that the pump and heating issues are certainly coincidences, and of course they will say the same about the pool leak. But that is a LOT of coincidences happening right after the sand change. Any advice/thoughts on whether these could be related? More specifically - any guidance on where to start thinking/looking for a leak - if it does have some connection to the filter change - that might help mitigate the costs of investigation?
