Hi guys,
My 2nd time opening my Fiberglass pool, here in Atlantic Canada. Ice on top of my pool just fully thawed out over the weekend. Last year I let the pool sit untouched for a few weeks after it thawed out and it eventually went green.
Right now, it's crystal clear as I think I did a solid closing. Water is still very cold, below 40F but warming slowly. So far I haven't opened the skimmer or return line plugs as I'm afraid they could re-freeze on a cold night. I am also hesitant to put the pump in so early out of fear of freezing.
I did water testing yesterday:
FC - 0
pH - 6.6 (ish, water was yellow, lighter than the lightest setting on comparator)
TA - 50
CH - 150
CYA - 10-20ish... solution was cloudy but had the tube fully filled up and could still slightly see the dot...
Salt - 1200
Water crystal clear, most organics are out (was very thorough cleaning out leaves before winter, unlike prior year).
I dumped 1 gal of bleach in the pool yesterday (after testing) out of precaution and stirred the pool a bit. It`s my understanding that little to nothing grows at these temps but don`t want to risk it.
Should I wait and just keep adding bleach until things warm a bit? Should I try to raise pH now or can that wait as well?
FC - 0
TA - 50
CH - 150
Salt - 1200
