The pool is an above ground oval, everything is vinyl or plastic. I opened it June 5th and the level was very low possibly the pump that clears the cover was draining some pool water too. We use well water to fill the pool and the first day or two it was a beautiful clear blue but I did not have my TF100 kit yet. It then became green and there was algae on the bottom that I vacuumed and shocked. Due to the way my pump filter is designed, I have to vacuum directly into the filter. The pool was still light green days later so I opened the filter which was green and cleaned it well, shocked again, and after a couple of days while waiting for my TF100 to arrive I got a test done by Leslie's. The pool was just opened and only shocked so the levels were abysmal but they were as follows:
Leslie's test on June 13th after only shocking and opening:
FC 14.59
TC 15
PH 7.3
TA 38
CH 13
CYA 21
Copper 0.3
Phosphates 1436
I immediately brought the CYA and TA up. The chlorine only dropped 1 since their test so maybe I shouldn't have added the CYA yet.
TF-100 kit June 15th:
FC 13
CC 13.5
PH 7.2
TA 70
CYA 50
CH 50
It's been bright and sunny, I use liquid chlorine, so I'm hoping the excess chlorine just burns off. But I do not know why the pool is still green other than maybe the copper being a little high. We've always refilled with well water without issue. And it's not some well in the mountains it's a suburb and we use well for our sprinkler system and to top off the pool every season, never had an issue. Not sure what else could be going on, my dad mentioned chlorine block and to add Pool Dechlorinator Sodium Thiosulfate Pentahydrate from amazon.
Kinda stuck! Any advice would help.
FC 14.59
TC 15
PH 7.3
TA 38
CH 13
CYA 21
Copper 0.3
Phosphates 1436
FC 13
CC 13.5
PH 7.2
TA 70
CYA 50
CH 50
