Hey all -
I live in Dallas and have a pool (plaster, 15k gallons) with no real deep end - about 5.5 ft at the deepest - and gets mostly full sun.
I am having an insanely difficult time getting my chlorine usage under control -
About a month ago I had a CYA around 70 and did SLAM the pool and had an overnight test that passed, but even after that I was routinely dumping 2/3 gallon per day of 10% chlorine in. It was from home depot, but was only a few weeks old so definitely not perfect, but still seems high.
After trying for several weeks to get it under control, I decided to do another partial dump and got my CYA down to 40. Other numbers looked relatively good to me -
PH was 7.8
TA was 90
CH was 220
CYA seemed to settle around 40 (though it took a few days for me to start seeing this)
Did an overnight test yesterday to see how things looked:
I overshot my initial target of 16ppm for SLAM...
(measured w/ fas-dpd @ 10ml sample)
7/8 @ 10:30pm - 22.5ppm
7/9 @ 4:30am - 20ppm, so it appears there is something going on
7/9 @ 10:30am - 16ppm (which is SLAM level for 40 CYA if I'm reading right)
7/9 @ 12:00pm - 12ppm, so I added 96oz which is more than was called for, but I'm also trying to account for the fact that my chlorine is probably not 10% anymore
7/9 @ 3:30pm - 8ppm
That seems insane to me - the pool LOOKS fantastic. Pump (cartridge filter) was cleaned out a few weeks ago and I even replaced the cartridges because the old ones were in bad shape....
I guess I'm kind of stuck. I'm going to keep driving the SLAM, but am running out of fas-dpd material and the one I ordered won't be here for 2 weeks and our local HD keeps running out of chlorine (I have 5 gallons left right now).
Is there anything I'm missing that would cause this? I think I obviously need to finish the SLAM and probably bump my CYA, I guess I'm just struggling cause it seems like even with some organics that is a TON of chlorine to eat. I've been buying the 3 packs of 10% that are about $10 and I'd say over the last 6 weeks I've easily spent over $150 on chlorine....
PH was 7.8
TA was 90
CH was 220
7/9 @ 3:30pm - 8ppm
