- May 3, 2014
- 59,099
- Fiberglass
- Pentair Intellichlor IC-40
Adding stablizer that way directly to the skimmer is not recommended anymore. Primarily because with sand or DE filters you then must wait a week or more before the stabilizer is fully dissolved. And some will never dissolve and sit in the no flow areas of the filter.
Always put stabilizer in a sock and hang in front of a return or put in the skimmer if you are running your pump 24/7. It will show up in your water within 24 hours after it is fully dissolved.
It sounds like in your case it acted about like DE, it plugged off your filter enough to restrict flow.
Sand is the best media for a sand filter. It has been around a million years and does not wear out.
