My pool heater will make a loud banging sound on occasion indicating that the water inside is boiling.
My initial finding is that my low pressure switch is not working correctly since I used to get a LO indication and the heater would turn off if I turn the outside bypass valve creating a low flow situation. But wouldn’t the low pressure valve normally fail in a position so the pool heater can’t start?
My question is just, is that the only thing that’s wrong? Should there be other safety measures preventing a boiling scenario?
I’ve read that the internal bypass may be bad. How can I check this?
Heater is a Hayward H400
