- Jul 21, 2013
- 65,708
- Plaster
- Pentair Intellichlor IC-60
My walmart down the street says it has that in stock. Will go get some. Says above i may need about six jugs. How many should i add tonight?
A gallon of 10% will raise your FC by 5.6 ppm. 4 gallons will get you to shock level of 20. Then you will see if the pool holds that level. If it is mostly dirt then you will not see a big FC loss or CCs. Get 6 gallons so if you lose some FC you can top it off tonight.
You have MA to lower your pH to 7.2 before you add the 4 gallons of LC?
You using PoolMath?
