Hello,
I haven't posted much since I found this site during my first pool crisis several years ago. Your sage advice has kept me "Trouble Free" since then; much appreciated. I live in NC and do not winterize my pool since it was built in 2011. This week I noticed the water level was low. I added water, but today I looked at the pump and filter to see where the water was going. The pad that the filter sits on is wet, with water running off of it. The pump sits on the same pad, but it's dry around the pump. I have a Jandy CV340 cartridge filter. I felt around the inlet, outlet, drain and vent connections, no water. I checked around the circumference beneath the o-ring, but it's dry. There appears to be water running from beneath the filter. I looked at the manual and there do not appear to be any other sources of leaks in the bottom half of the filter, unless it has developed a crack. I didn't find any posts of cracked housings on the internet, but I do see that Jandy sells a "bottom housing assy".
Anyone else heard of one cracking? Rather than replacing, is there any material that can be used to seal such a crack if I can find it? I tried to call Jandy, but they are closed for the holidays. I have a couple of days off where I could work on this, so I thought I'd hit you guys up in case anyone has experienced this.
Happy Holidays to all!
NCTim
NCTim
